JS5641
Aug 14, 2022Follower
Cm1200 and AX8 nighthawk internet connection issues
Have cm1200, connects to internet with a Ethernet cable from (direct connect) pc to cable modem. Have a nighthawk AX 8 connected to the cm1200, but no internet. Green icon on CM 1200, red on AX8. Both...
Aug 15, 2022Guru - Experienced User
Make sure nothing else is connected to the cm1200. It might have 4x ports but the majority of ISP's only support 1 connected device.
