Fe2O3y
Nov 06, 2020Aspirant
CM1200 and Google Wifi (Gen 1)
I upgraded my Arris SBG6900AC to the Netgear CM1200 as I'm looking to upgrade my internet speeds. I currently have a Google Wifi (Gen 1). With the Surfboard modem (router radio disabled), I was consi...
- Nov 06, 2020
With the SBG6900AC yes. Because it has an integrated router.
With the CM1200, no. it is a modem only. There's zero routing funtions to it.
Nov 06, 2020Guru - Experienced User
are you able to connect a pc to the CM1200 and get full speeds?
- Fe2O3yNov 06, 2020Aspirant
Yes, I can. I connected a laptop to the modem and was able to access the Netgear config screen and have access to the internet.
- plemansNov 06, 2020Guru - Experienced User
try this.
1. Factory reset the cm1200 and the google wifi.
2. after the reset, power them both down and disconnect everything from both. even coax from the modem.
3. connect coax back to the cm1200 and power it on. give it several minutes.
4. connect the google wifi back to the cm1200
5. power the google wifi back on. give it several minutes.
6. attempt new setup of the google wifi
Thank you. I am on a conference call for the next 90 minutes, but will try that and advise.
Not sure if it's pertinent, but this is a Certified Refurbished unit.
the google wifi or the cm1200?
Shouldn't really matter.
