Fe2O3y's avatar
Fe2O3y
CM1200 and Google Wifi (Gen 1)
I upgraded my Arris SBG6900AC to the Netgear CM1200 as I'm looking to upgrade my internet speeds. I currently have a Google Wifi (Gen 1). With the Surfboard modem (router radio disabled), I was consi...
  • plemans's avatar
    Nov 06, 2020
    With the SBG6900AC yes. Because it has an integrated router.
    With the CM1200, no. it is a modem only. There's zero routing funtions to it.
