rjbiv's avatar
rjbiv
CM1200 and R6400v2, should I upgrade the router
I've had the R6400V2 router for a few years now. Just switched out the Cox panoramic modem for my own CM1200. On various devices and apple tv units, it shows connected but not getting internet. One ap...
  • FURRYe38's avatar
    Jan 17, 2020
    If you have 1Gb services from your ISP, the router you have currently may not fully support those speeds, so yes, I would upgrade the router. NGs R series or XR if your a gamer, or RAX if you need wifi AX support.
