Darksound
Aug 17, 2024Aspirant
CM1200 and XR1000v1
Can anyone tell me what these logs mean? I keep getting frequent Internet drops. I have a XR1000 gaming router as well. I was having issues so I've updated the firmware to 1.0.0.72_1.0.62 and factory...
Aug 18, 2024Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem. https://highspeed.tips/docsis-events/
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- DarksoundAug 18, 2024Aspirant
thank you!
Here is the cable connection page.
- FURRYe38Aug 18, 2024Guru - Experienced User
You have tons of errors on channels 1 and 17 and up. All should be zeros.
Review the suggestions given along with having the ISP check things and check the event logs. They need to look into this.
Good Luck.
