TONEHZ
Jul 27, 2021Guide
CM1200, Asus AX-86U & Comcast 1.2Gb internet
Issue: I've got comcast 1.2GB speed, provisioned 1400Mbps and I want to take full advantage of what is paid for. Currently getting 940mbps. Equipment: CM1200 modem. Asus AX-86u router. Currently ...
- Jul 29, 2021^ for sure, rest assured the modem was restarted many times and so was the router, being left off for periods of 10 minutes or more. I want to point that out so the issue isn’t downplayed into me just not letting the modem lose power. I also got a new CM2000 modem and that should have been correctly configured with the provisioned speeds but still limited bandwidth to 940mbps, nothing was changed on the router. I’ve had gigabit service for years and the 1200mbps has been available in my area for months now while I’ve been receiving 940mbps, of course I didn’t have aggregation turned on so I wouldn’t have noticed but even when I did it didn’t work until the main tap cable lines were messed with. Of course it could also have been during that downtime when the line was messed with it was the sufficient time needed to reprovision the modem but I highly doubt that to be the case, a new modem rules that out, so do the numerous power outages that would have reprovisioned the modem during the months I’ve had the 1200mbps service. Such an odd issue. If anyone struggles, definitely leave modem and router devices unplugged for atleast 5 minutes to rule them out and to check your main cable lines directly from the tap. In the very end it’s most likely I just wasn’t provisioned correctly and the Comcast reps couldn’t tell otherwise.
Jul 29, 2021Guru - Experienced User
Let us know how it goes...
TONEHZ
Jul 29, 2021Guide
Update: I had the old cable line hooked back up and plugged the CM1200 back in, reactivated, and now I am getting 1300+mbps over aggregation between the RT-AX86u and the CM1200 across multiple devices, totaled. This process has been insanely frustrating for me but I have learned a lot but ended up doing nothing. At this point in my conclusion, it seemed like "unplugging the cable line & plugging it back in" worked, (for whatever reason that may have sent a new provision from 940mbps to 1200mbps, all ethernet cables kept the same, so I'm not sure if any/what variable actually changed, connections were super tight before, all reps said I was receiving the correct strong signal the entire time, maybe nothing happened), moving on, I'll be returning the CM2000. I'll update once again when I get my network card for my PC and can access all 1200mbps+ from one device and see if everything is working properly that way.
So far if you have these 2 devices you can at least save yourself money and don't need to upgrade your modem to access higher than gigabit speeds. So if you have weird issues where it isn't working as intended, don't give up.
- FURRYe38Jul 29, 2021Guru - Experienced User
Good to hear. Thanks for the update.
One thing to remember and the ISP should tell you this as well. If there is ANY change in modem services from the ISP, the modem needs to be powered OFF fully for at least 1 minute. Then back ON. Then any updates and config changes should be seen by the modem.
Glad you got it working. Please mark your thread as solved so others will know.Enjoy.
- TONEHZJul 29, 2021Guide^ for sure, rest assured the modem was restarted many times and so was the router, being left off for periods of 10 minutes or more. I want to point that out so the issue isn’t downplayed into me just not letting the modem lose power. I also got a new CM2000 modem and that should have been correctly configured with the provisioned speeds but still limited bandwidth to 940mbps, nothing was changed on the router. I’ve had gigabit service for years and the 1200mbps has been available in my area for months now while I’ve been receiving 940mbps, of course I didn’t have aggregation turned on so I wouldn’t have noticed but even when I did it didn’t work until the main tap cable lines were messed with. Of course it could also have been during that downtime when the line was messed with it was the sufficient time needed to reprovision the modem but I highly doubt that to be the case, a new modem rules that out, so do the numerous power outages that would have reprovisioned the modem during the months I’ve had the 1200mbps service. Such an odd issue. If anyone struggles, definitely leave modem and router devices unplugged for atleast 5 minutes to rule them out and to check your main cable lines directly from the tap. In the very end it’s most likely I just wasn’t provisioned correctly and the Comcast reps couldn’t tell otherwise.
:smileywink: Enjoy.
This is how that network card is doing. A nice steam download.
