drstephennix
Feb 11, 2021Aspirant
CM1200 Cable Modem with Asus RT-AX82U
I have the setup in the subject line. I came home one day and internet was completely down. restarting didn't work and after talking to Asus support. I had to make new 2.4 and 5g networks. I've g...
- Feb 11, 2021
If the modem is putting out the full speeds you pay for, then you should be checking with asus support/community on its router.
The modem doesn't do much other than provide a connection to the router. And if its hitting its speeds, check on the router.
Feb 11, 2021Guru - Experienced User
there's not much to adjust in the modem.
What speeds do you get hardwired into the modem?
drstephennix
400mbps and I just did a speed test on my work computer and getting a little more than that. wifi seems slower though
