drstephennix's avatar
drstephennix
CM1200 Cable Modem with Asus RT-AX82U
I have the setup in the subject line.  I came home one day and internet was completely down.  restarting didn't work and after talking to Asus support.  I had to make new 2.4 and 5g networks.  I've g...
  • plemans's avatar
    Feb 11, 2021
    If the modem is putting out the full speeds you pay for, then you should be checking with asus support/community on its router.
    The modem doesn't do much other than provide a connection to the router. And if its hitting its speeds, check on the router.
