sixsevans's avatar
Aug 11, 2019
CM1200. Can ports 2,3,4 be used other than for Port Aggregation?
The description on Amazon says: VERSATILE CONNECTIONS: 4 Gigabit Ethernet ports give you fast wired connections to your computer, separate Wi-Fi router, printer, game box, and other devices. But ...
  • plemans's avatar
    Aug 11, 2019
    Port 1 & 2 can be used for port aggregation. The other ports can't be used unless your ISP provisions you with multiple IP addresses (one for each port)
