tmbrwolf
Jul 13, 2019Tutor
cm1200 cannot access 192.168.100.1
I just got a CM1200 cable modem and activated it on Comcast without problem. I have no problem with internet access, but I cannot access the configuration page at 192.168.100.1. To debug this. I've g...
- Jul 13, 2019
Sounds like the modem configuration is bad or the modem itself if bad. Try another.
One thing to try, is disconnect the coax from the modem, factory reset, does your direct connect PC access the modems web page? If not, Need a new one.
Jul 13, 2019Guru - Experienced User
- tmbrwolfJul 14, 2019Tutor
Apparently a factory reset while disconnected from the coax did the trick. (Either that or the modem hard me talking about returning it.) I'm able to access the config page now.
Thanks for the suggestion.
- FURRYe38Jul 15, 2019Guru - Experienced User
Possible the modem was in a bad state. Glad its working now.
Enjoy.
