tmbrwolf's avatar
Jul 13, 2019
cm1200 cannot access 192.168.100.1
I just got a CM1200 cable modem and activated it on Comcast without problem. I have no problem with internet access, but I cannot access the configuration page at 192.168.100.1. To debug this. I've g...
  • FURRYe38's avatar
    Jul 13, 2019
    Sounds like the modem configuration is bad or the modem itself if bad. Try another.
    One thing to try, is disconnect the coax from the modem, factory reset, does your direct connect PC access the modems web page? If not, Need a new one.
