aero36's avatar
aero36
CM1200 Compatibility with Routers and ISP
Hello everyone! I am trying to get off the rented modem/router we get from RCN and was looking at the CM1200 and was hoping you guys could help make sure I don't buy something I can't use!
Modem: https://www.amazon.com/NETGEAR-Nighthawk-Cable-Modem-CM1200/dp/B07Q5VM51Y
Now I first want to make sure this works with RCN and also that it would be compatible with the non-Netgear AX router I am looking to get:
Router: https://www.amazon.com/dp/B07HM6KJN8/?th=1&tag=linus21-20
Also, as an extra I use a MOCA - does anyone see any potential issues with this setup for that?
Thank you in advance for your help!
  • plemans's avatar
    You'd have to check with RCN to see if its compatible with their service.
    It'd be compatible with the router you listed.
