DaveyBoy918
Aug 15, 2021Follower
CM1200 connection to PS4
Trying to connect ps4 directing to modem. It connects to route perfectly fine but would like to take advantage of hard lining straight to modem. Modem is the netgear nighthawk cable modem CM1200
Aug 16, 2021Guru - Experienced User
The CM modem is NOT a router. You need a wired or wireless router in between the modem and PS4.
