Pibe38
May 03, 2020Aspirant
[CM1200] Constant Internet Drop on Spectrum
Hello, A few days ago I decided to purchase my own modem. I originally purchased the Arris SB8200. 24 hours after activation I started having my connection drop every so often; it would come back...
Pibe38
Thank you FURRYe38, are those standard things to check or do you see something on the logs that could indicate an issue?
May 03, 2020Guru - Experienced User
Those are standard things to check first always.
Seems that if you had a SB8200 that exhibited problems and now have a CM1200 thats having problems, seems like this maybe a service or line issue.
