xkyc
Nov 17, 2020Aspirant
CM1200 disconnects
I was having slow internet not long ago, I bought Netgear Nighthawk CM1200 & X6 since it was widely recommended. After getting it installed and set up, it worked amazing...for About 12 hours. Then it...
xkyc
Nov 26, 2020Aspirant
ISP signal is great. Everything from their node to my RG6 is brand new and tested great. It is not their issue. I've been running the Motorola since I made the orignal post with zero issues.
Firmware Version V3.02.01
As far as disabling LAG, I don't see that option in the modems control panel. But I did see this, "Ethernet Port Aggregation Status: Inactive" and I'm unsure if that related or not.
Nov 26, 2020Guru - Experienced User
Can try a different power supply with matching voltage and amps to see.
I would make contact with NG support and ask about an RMA.
- xkycNov 26, 2020Aspirant
NG support was absoultly awful. The rep told me that any issue is never the modems issue, told me I had to pay for extended support in order to do anyhing else. After talking with them it sounds like I got the short end of the stick. NG got me for around $500 but I am certain it wont happen again. smh
- FURRYe38Nov 26, 2020Guru - Experienced User
