zbrozek
Jul 28, 2019Tutor
CM1200 does not assign IP address unless Ethernet cable is unplugged and plugged back in
I bought a CM1200 yesterday to replace a super-flaky SB8200. Unfortunately, the CM1200 only allows me to get an IP address right after cycling the Ethernet cable. This is a problem, as whenever I chan...
zbrozek
Jul 29, 2019Tutor
Same problem reproduces with six different cables, including the brand-new one that shipped with the CM1200.
Jul 29, 2019Guru - Experienced User
What device do you have connected to the modem? PC or External router? Mfr and model#?
- zbrozekJul 29, 2019Tutor
I've tried two devices. One is plan-of-record, the other is for debugging.
Debugging device is an ancient WRT54G. Plan-of-record device is a computer with an Intel NIC attached to a VM running pfsense. Right now whenever I change a setting on the WRT54G, it reboots itself. With the VM, if I ever reboot it, the NIC doesn't actually bring down the PHY - it just asks for a new IP on restart.
It doesn't seem like there should be any connection between responding to a DHCP request and link history.
- FURRYe38Jul 29, 2019Guru - Experienced User
Any chance you have a more up to date router? Something to test with to see if the CM still hands out and IP with out having to unplug and plug in the LAN cable?
I didn't see this issue with my 1200...
The VM is about as up-to-date as it gets. That said, I see the same behavior with my Thinkpad. If I unplug the cable and replug it in, the next dhcp client request works fine.
I'll try to collect more data, including some tcpdump logs.
