JTam365
Dec 12, 2022Aspirant
CM1200 Downstream blinking with sync loss
Downstream is always blinking green meaning loss of sync. It is always the same channel not locking. 513mhz. Power levels look good except for slightly high upstream. See attached. No splitters ...
- Dec 14, 2022
Solution: ISP tech showed me where he was getting all green on his line check. Said it was probably the modems error. After I said it was only 1 channel not locking and high upstream power he made a phone call and hooked up a spectrum analyzer and found a bad channel on his side. Called in a lineman who found a bad amp inline. Now getting no errors and all power levels in spec! Note: Blinking downstream led is a good indicator of high upstream power (modem is shouting to the CMTS)
JTam365
Router is Netgear R6700AX wired with cat6. Will try to bypass my home CATV wire with cat6.
Dec 13, 2022Guru - Experienced User
RG6 coax cable is needed from the ISP service box up to the modem.
Then from the modem to your wifi router needs to be LAN cable, CAT6 recommended.
If have your ISP check and review the suggestions given...
- JTam365Dec 14, 2022Aspirant
- FURRYe38Dec 14, 2022Guru - Experienced User
Glad you got it working. Thanks for letting us know.
Enjoy.
