JTam365
Dec 12, 2022Aspirant
CM1200 Downstream blinking with sync loss
Downstream is always blinking green meaning loss of sync. It is always the same channel not locking. 513mhz. Power levels look good except for slightly high upstream. See attached. No splitters ...
- Dec 14, 2022
Solution: ISP tech showed me where he was getting all green on his line check. Said it was probably the modems error. After I said it was only 1 channel not locking and high upstream power he made a phone call and hooked up a spectrum analyzer and found a bad channel on his side. Called in a lineman who found a bad amp inline. Now getting no errors and all power levels in spec! Note: Blinking downstream led is a good indicator of high upstream power (modem is shouting to the CMTS)
JTam365
Dec 14, 2022Aspirant
Dec 14, 2022Guru - Experienced User
Glad you got it working. Thanks for letting us know.
Enjoy.
