Here is the cable connection log:
| Startup Procedure |
| Procedure | Status | Comment | | Acquire Downstream Channel | 453000000 Hz | Locked | | Connectivity State | OK | Operational | | Boot State | OK | Operational | | Security | Enabled | BPI+ | | IP Provisioning Mode | IPv6 Only | ipv6Only(1) |
| Downstream Bonded Channels |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables | | 1 | Locked | QAM256 | 1 | 453000000 Hz | 6.2 dBmV | 43.6 dB | 0 | 0 | | 2 | Locked | QAM256 | 2 | 459000000 Hz | 6.1 dBmV | 43.4 dB | 0 | 0 | | 3 | Locked | QAM256 | 3 | 465000000 Hz | 6.5 dBmV | 43.6 dB | 0 | 0 | | 4 | Locked | QAM256 | 4 | 471000000 Hz | 6.6 dBmV | 43.4 dB | 0 | 0 | | 5 | Locked | QAM256 | 5 | 477000000 Hz | 7 dBmV | 43.2 dB | 0 | 0 | | 6 | Locked | QAM256 | 6 | 483000000 Hz | 7.1 dBmV | 43.6 dB | 0 | 0 | | 7 | Locked | QAM256 | 7 | 489000000 Hz | 7.3 dBmV | 43.7 dB | 0 | 0 | | 8 | Locked | QAM256 | 8 | 495000000 Hz | 7.3 dBmV | 43.7 dB | 0 | 0 | | 9 | Locked | QAM256 | 9 | 507000000 Hz | 7.6 dBmV | 43.7 dB | 0 | 0 | | 10 | Locked | QAM256 | 10 | 513000000 Hz | 7.7 dBmV | 43.7 dB | 0 | 0 | | 11 | Locked | QAM256 | 11 | 519000000 Hz | 8 dBmV | 43.8 dB | 0 | 0 | | 12 | Locked | QAM256 | 12 | 525000000 Hz | 7.8 dBmV | 43.6 dB | 0 | 0 | | 13 | Locked | QAM256 | 13 | 633000000 Hz | 7.9 dBmV | 42.7 dB | 0 | 0 | | 14 | Locked | QAM256 | 14 | 639000000 Hz | 6.9 dBmV | 42.4 dB | 0 | 0 | | 15 | Locked | QAM256 | 15 | 645000000 Hz | 8.1 dBmV | 42.9 dB | 0 | 0 | | 16 | Locked | QAM256 | 16 | 651000000 Hz | 8.2 dBmV | 42.9 dB | 0 | 0 | | 17 | Locked | QAM256 | 17 | 657000000 Hz | 8.2 dBmV | 43 dB | 0 | 0 | | 18 | Locked | QAM256 | 18 | 663000000 Hz | 8.2 dBmV | 42.8 dB | 0 | 0 | | 19 | Locked | QAM256 | 19 | 669000000 Hz | 8.1 dBmV | 42.8 dB | 0 | 0 | | 20 | Locked | QAM256 | 20 | 675000000 Hz | 8 dBmV | 41.9 dB | 0 | 0 | | 21 | Locked | QAM256 | 21 | 681000000 Hz | 8.2 dBmV | 42.8 dB | 0 | 0 | | 22 | Locked | QAM256 | 22 | 687000000 Hz | 8.2 dBmV | 42.9 dB | 0 | 0 | | 23 | Locked | QAM256 | 23 | 693000000 Hz | 8.2 dBmV | 43 dB | 0 | 0 | | 24 | Locked | QAM256 | 24 | 699000000 Hz | 8.2 dBmV | 43 dB | 0 | 0 | | 25 | Locked | QAM256 | 26 | 705000000 Hz | 8.2 dBmV | 43 dB | 0 | 0 | | 26 | Locked | QAM256 | 27 | 711000000 Hz | 8 dBmV | 42.9 dB | 0 | 0 | | 27 | Locked | QAM256 | 28 | 717000000 Hz | 8.2 dBmV | 42.9 dB | 0 | 0 | | 28 | Locked | QAM256 | 30 | 729000000 Hz | 8.1 dBmV | 42.7 dB | 0 | 0 | | 29 | Locked | QAM256 | 31 | 735000000 Hz | 7.9 dBmV | 42.5 dB | 0 | 0 | | 30 | Locked | QAM256 | 32 | 741000000 Hz | 8.2 dBmV | 42.8 dB | 0 | 0 | | 31 | Locked | QAM256 | 33 | 747000000 Hz | 7.9 dBmV | 42.4 dB | 0 | 0 | | 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| Upstream Bonded Channels |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 33 | 5120 Ksym/sec | 17800000 Hz | 48.8 dBmV | | 2 | Locked | ATDMA | 34 | 5120 Ksym/sec | 24200000 Hz | 48.8 dBmV | | 3 | Locked | ATDMA | 35 | 5120 Ksym/sec | 30600000 Hz | 49 dBmV | | 4 | Locked | ATDMA | 36 | 5120 Ksym/sec | 37000000 Hz | 49.3 dBmV | | 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| Downstream OFDM Channels |
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords | | 1 | Locked | 0 ,1 ,2 | 25 | 266000000 Hz | 6.9 dBmV | 43.9 dB | 148 ~ 3947 | 96631055 | 30940223 | 0 | | 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
| Upstream OFDMA Channels |
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | | 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | | 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
