Ashhan
Dec 15, 2021Guide
CM1200 Dropping Connection
For the past 2-3 weeks my internet connection has been spotty, my connection drops about 3-4 per hour, for durations of 45 seconds - 5 minutes. Getting high ping/bad connection in games, media stream...
Dec 16, 2021Guru - Experienced User
do you have an amplifier in your line?
Your downstream signal is very strong which usually indicates you're close to a hub.
But your upstream signal is high and that usually indicates you're quite a ways away from the hub.
So I'm curious why its not balanced properly.
- AshhanDec 20, 2021Guide
As far as I know, we do not have an amplifier in the line.
- plemansDec 20, 2021Guru - Experienced User
check it for amplifiers or even for splitters.
Sometimes causing the power imbalance. And while technically both are in spec for power levels, they don't make sense.
Where would I look for amplifiers or splitters?
I had a "technician" from my ISP come out a few days ago and he ran a new line from outside into my house, but that seemed to change nothing. Is there anything specific I should bring up to the next "technician" that comes by?
