Ashhan
Dec 15, 2021Guide
CM1200 Dropping Connection
For the past 2-3 weeks my internet connection has been spotty, my connection drops about 3-4 per hour, for durations of 45 seconds - 5 minutes. Getting high ping/bad connection in games, media stream...
Ashhan
Dec 20, 2021Guide
As far as I know, we do not have an amplifier in the line.
Dec 20, 2021Guru - Experienced User
check it for amplifiers or even for splitters.
Sometimes causing the power imbalance. And while technically both are in spec for power levels, they don't make sense.
- AshhanDec 20, 2021Guide
Where would I look for amplifiers or splitters?
I had a "technician" from my ISP come out a few days ago and he ran a new line from outside into my house, but that seemed to change nothing. Is there anything specific I should bring up to the next "technician" that comes by?
- plemansDec 20, 2021Guru - Experienced User
Are you directly connected to the new line that is coming in? It runs directly from the outside to in the home and connected to the modem? Nothing else connected? No splitters, amplifiers, signal attenuators or anything?
Within my house, yes the cable that runs from outside comes directly into my modem. I will go and take a look outside to see what the situation out there is looking like.
