| Time | Priority | Description |
| Sat Jul 01 14:54:14 2023 | Error (4) | Primary address failed, secondary active;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 14:54:14 2023 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | DHCP failed - RS sent, no RA received;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = APM |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 14:20:26 2023 | Error (4) | Primary address failed, secondary active;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 14:20:26 2023 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 12:20:26 2023 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:58:01 2023 | Error (4) | Primary address failed, secondary active;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:58:01 2023 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:58:06 2023 | Critical (3) | DHCP failed - RS sent, no RA received;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:57:50 2023 | Notice (6) | Honoring MDD; IP provisioning mode = APM |
| Sat Jul 01 11:57:42 2023 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:57:40 2023 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:57:30 2023 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:57:21 2023 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:57:18 2023 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:57:15 2023 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:57:07 2023 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Sat Jul 01 11:53:30 2023 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 21:24:05 2023 | Error (4) | Primary address failed, secondary active;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 21:24:05 2023 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 21:24:03 2023 | Critical (3) | DHCP failed - RS sent, no RA received;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 21:23:47 2023 | Notice (6) | Honoring MDD; IP provisioning mode = APM |
| Fri Jun 30 21:23:40 2023 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 21:23:29 2023 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 21:23:28 2023 | Notice (6) | CM-STATUS message sent. Event Type Code: 6; Chan ID: 65; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 21:23:27 2023 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 21:23:26 2023 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 21:23:18 2023 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 21:19:28 2023 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 20:48:59 2023 | Error (4) | Primary address failed, secondary active;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 20:48:59 2023 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 20:48:57 2023 | Critical (3) | DHCP failed - RS sent, no RA received;CM-MAC=94:a6:7e:d8:68:1c;CMTS-MAC=00:01:5c:be:54:46;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jun 30 20:48:41 2023 | Notice (6) | Honoring MDD; IP provisioning mode = APM |
