TylUmp
Jul 01, 2023Aspirant
CM1200 Dropping Multiple Times
I have contacted Optimum multiple times to update our firmware which they refuse to do. I have attached screenshots of logs and settings. Any help would be greatly appreciated. Netgear told m...
Jul 01, 2023Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
You have Correctables and Un-Correctables that should be zeros:
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
TylUmp
Router is an Orbi RB750. The Orbi’s firmware is current.
Optimum came out and checked the line and reported zero issues with signal strength. I’m really at a loss.
2 years no issues, and then this mess.
- FURRYe38Jul 02, 2023Guru - Experienced User
All the items I outlined are on the ISP side of the modem. What the modem reports in the logs. Did the tech take a look at the logs?
Only other thing would be to rent the ISP modem for short term to see if theres does the same thing, if it does, then they need to fix there side. Seems that if the modem had been working ok and something suddently broke, ISP could have make a change or did some maintenance somewhere on your line causing problems.
- TylUmpJul 04, 2023Aspirant
Tech came back out yesterday and reported no concerns. I requested the check the line running underground to house. Upon doing so there have been no logged issues and no loss in connection.
Uncorrectables are now zeroed out. Any other other recommendations. FYI, ISP is refusing to upgrade firmware on modem.
Apply Cancel Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 447000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 24 447000000 Hz 3.4 dBmV 37 dB 1 0 2 Locked QAM256 1 309000000 Hz 1.7 dBmV 35.4 dB 10 0 3 Locked QAM256 2 315000000 Hz 1.5 dBmV 35.1 dB 34 0 4 Locked QAM256 3 321000000 Hz 1.2 dBmV 34.3 dB 18 0 5 Locked QAM256 4 327000000 Hz 1.5 dBmV 35.8 dB 4 0 6 Locked QAM256 5 333000000 Hz 1.4 dBmV 35.6 dB 37 0 7 Locked QAM256 6 339000000 Hz 1.3 dBmV 35 dB 10 0 8 Locked QAM256 7 345000000 Hz 0.5 dBmV 34.8 dB 8 0 9 Locked QAM256 8 351000000 Hz 1.4 dBmV 35 dB 1 0 10 Locked QAM256 9 357000000 Hz 1.6 dBmV 35.6 dB 1 0 11 Locked QAM256 10 363000000 Hz 2 dBmV 35.3 dB 0 0 12 Locked QAM256 11 369000000 Hz 2.2 dBmV 35.3 dB 0 0 13 Locked QAM256 12 375000000 Hz 2.4 dBmV 35.7 dB 0 0 14 Locked QAM256 13 381000000 Hz 2.5 dBmV 35.2 dB 19 0 15 Locked QAM256 14 387000000 Hz 2.4 dBmV 36 dB 0 0 16 Locked QAM256 15 393000000 Hz 2.5 dBmV 36.1 dB 0 0 17 Locked QAM256 16 399000000 Hz 3.1 dBmV 36.3 dB 2 0 18 Locked QAM256 17 405000000 Hz 3.5 dBmV 36.2 dB 1 0 19 Locked QAM256 18 411000000 Hz 3.6 dBmV 36.3 dB 1 0 20 Locked QAM256 19 417000000 Hz 3.5 dBmV 36.6 dB 1 0 21 Locked QAM256 20 423000000 Hz 3.3 dBmV 36.7 dB 0 0 22 Locked QAM256 21 429000000 Hz 3.5 dBmV 36.7 dB 0 0 23 Locked QAM256 22 435000000 Hz 3.5 dBmV 36.6 dB 1 0 24 Locked QAM256 23 441000000 Hz 3.4 dBmV 36.7 dB 1 0 25 Locked QAM256 25 453000000 Hz 3 dBmV 37 dB 0 0 26 Locked QAM256 26 459000000 Hz 3 dBmV 36.9 dB 1 0 27 Locked QAM256 27 465000000 Hz 2.9 dBmV 36.7 dB 0 0 28 Locked QAM256 28 471000000 Hz 2.9 dBmV 36.9 dB 0 0 29 Locked QAM256 29 477000000 Hz 2.8 dBmV 37.1 dB 0 0 30 Locked QAM256 30 483000000 Hz 2.6 dBmV 37.1 dB 0 0 31 Locked QAM256 31 489000000 Hz 2.2 dBmV 37.1 dB 0 0 32 Locked QAM256 32 495000000 Hz 2.2 dBmV 37.2 dB 0 0 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 65 5120 Ksym/sec 35500000 Hz 44.5 dBmV 2 Locked ATDMA 66 5120 Ksym/sec 28700000 Hz 43.5 dBmV 3 Locked ATDMA 67 2560 Ksym/sec 23500000 Hz 42.8 dBmV 4 Locked ATDMA 68 2560 Ksym/sec 19900000 Hz 43.3 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels
Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Extended Upstream Transmit PowerEnable Extended Upstream Transmit Power
- FURRYe38Jul 04, 2023Guru - Experienced User
IF there hasn't been any more connection issues, let it run this week and see how it goes.
I still see some correctables and un-correctables however they are minimal. There would be some cable like issue here that causes that. But lets see how the modem runs this week and observe.
Ya, ISPs can refuse to update user owned modems. Nothing we can do about that.
