Lito628
Feb 08, 2021Tutor
CM1200 Drops Internet
My modem is new and prior to this modem, my internet did not drop. Now every 15-20 the modem Internet LED light goes off and my internet drops then after a few mins it will start blinking and connect ...
Feb 08, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- Lito628Feb 09, 2021TutorStartup Procedure
Procedure Status Comment
Acquire Downstream Channel 801000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enabled BPI+
IP Provisioning Mode Honor MDD honorMdd(4)- FURRYe38Feb 09, 2021Guru - Experienced User
Need the Downstream and Upstream sections from that page...
