Pcyph3r's avatar
Pcyph3r
CM1200 has netgear and comcast pointing fingers with no end (solution) in sight
this started almost 3 weeks ago now, I have had the same modem (CM1200) connected in my house for almost a year. No issues, never skipped a beat. I havent changed anything in my setup. now i am havin...
  • plemans's avatar
    Feb 28, 2022
    Your connection info looks pretty good (other than a few errors)
    Your log indicates line issues.
    Another option you have would be to rent a modem from xfinity because then they can't blame it on 3rd party devices.
    Reason why sometimes a reset/reboot fixes it is the modem might be having issues with specific channels/ranges.
    when it reboots/resets, it can use a different channel/range and be fine on that range. But when the cmts switches it, it causes issues.
