Airguard6
Sep 25, 2024Aspirant
CM1200 intermittent connection issues.
I have had my ISP send out technicians multiple times now and they have checked signals on the coaxial cables and replaced fittings outside the house and within. They also checked my ethernet cable ru...
Sep 26, 2024Guru - Experienced User
the power levels are low and you have a ton of errors.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
Airguard6
Sep 26, 2024Aspirant
Thanks Plemans,
The technicians checked the coax for everything you're mentioning here and replaced all the connectors just in case.
