Airguard6
Sep 25, 2024Aspirant
CM1200 intermittent connection issues.
I have had my ISP send out technicians multiple times now and they have checked signals on the coaxial cables and replaced fittings outside the house and within. They also checked my ethernet cable ru...
Sep 26, 2024Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
