wildman22john
Jul 09, 2022Aspirant
CM1200 Intermittent connection issues with WOW cable
I've been having connection issues with WOW cable and my CM1200 modem the last couple of months. Almost every afternoon the connection drops and then intermittently drops the rest of the evening. I...
Jul 09, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- wildman22johnJul 09, 2022Aspirant
Cable connections screenshot. Just replaced cable between modem and router with a Cat6. Modem is hooked up to Google wifi hub.
- FURRYe38Jul 10, 2022Guru - Experienced User
Well your power levels are all over the place. Some Higher, some lower. You have correct and un-correcables that should all be zeros.
Check for ISP coax cabling and fittings and splitters. Ensure coax jack fittings are screwed in well and snug.
ISP need to check signal up to the modem. Power levels on all channels should all be in the same range.
