okfrontier
Oct 27, 2021Aspirant
CM1200 Intermittent slow internet
Purchased this Netgear Nighthawk CM1200 on Amazon in June 2020. Started noticing intermittent "circle of death" while streaming TV shows using my Apple TV. I bought a new Nighthawk RAXE500 Router, th...
okfrontier
Cox replaced the Netgear modem with a rental modem. Would like to get the Netgear repaired if they will ever repair it since it is out of warranty???
Oct 27, 2021Guru - Experienced User
No sure if NG repairs modems.
If out of warranty, you'll need to probably purchase a support contract to make contact with NG support.
Just be cause they replaced the modem with theres doesn't mean the CM modem is entirely at fault. The questions presented would need to be checked. Posting this information as well would be helpful.
One thing you can try is to take the modem to a different location, say friend, family or nieghbor and see if the problem follows.
Also need to check the power adapter as well for the CM modem. These can fail or go bad.
- okfrontierOct 27, 2021Aspirant
Thanks for your suggestions, but Netgear wanted $89 for a 6 month service contract, and over $200 for a 2 year contract. I paid $200 for the modem to start, so I just returned the Cox rental modem and bought a Motorola MB8611 on Amazon which has same day delivery for $169. Going to give it a try, since the Netgear CM1200 lasted less than a year before it started to fail!!!
- FURRYe38Oct 27, 2021Guru - Experienced User
