findcanary
Feb 16, 2021Aspirant
CM1200 Internet Issues: Intermittent Slow, or Disconnection - Spectrum
Repost: Moved from https://community.netgear.com/t5/Orbi-AX/CM1200-Orbi-AX6000-Internet-Issues-Intermittent-Slow-or/m-p/2057659#M12311 Hi All! I appreciate everyone taking a quick read of this,...
Feb 16, 2021Guru - Experienced User
Make sure your Speeds are good at the CM modem with a wired PC using Ooklas installable speed test app. Not there web page. Check different servers as well for Ookla. Different servers may exhibit different results. Find one that works best on a constant basis. On a wired connection with a good CPU PC, you should see near or just over 900Mpbs.
Ensure LAG is disabled on the CM modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- findcanaryFeb 16, 2021Aspirant
FURRYe38 ,So, my wiring is all hidden, I'm not sure what it's doing behind enclosed drywall. So while I'd like to believe that it's a straight shot, I'm not sure. So before I start tearing my walls apart (joking) fishing wires through the wall, I'd like to know if singnals look good coming into the modem.
To be clear, I've tested from the Ookla app, using my ISP cloest location from my laptop running hardwired directly into the cable modem, with wireless disabled.
As to this
"Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly."
The two technicians both respond to me that it's not great, but it's within range. Which I have don't know what the means. I just feel like they don't actually want to check or repair anything, and I don't know enough to prove otherwise.
Specific to
"Ensure LAG is disabled on the CM modem"
I'm not sure what this is, maybe you can explain?
- FURRYe38Feb 16, 2021Guru - Experienced User
For LAG log into the modems web page at 192.168.100.1 with a wired PC and look for Link Aggregation. Disable if its enabled.
Also post the version of FW that the CM modem reports as well.
