findcanary
Feb 16, 2021Aspirant
CM1200 Internet Issues: Intermittent Slow, or Disconnection - Spectrum
Repost: Moved from https://community.netgear.com/t5/Orbi-AX/CM1200-Orbi-AX6000-Internet-Issues-Intermittent-Slow-or/m-p/2057659#M12311 Hi All! I appreciate everyone taking a quick read of this,...
findcanary
Mar 29, 2021Aspirant
Sorry I didn’t see this for some reason :(. I’m still having intermittent issues. May I ask when you say my power levels are a bit on the high side, what could cause that? My guess is that it’s bad cables or other interference that causes it to have to push harder to connect. However, that’s a complete guess maybe you can educate me?
Mar 29, 2021Guru - Experienced User
Power levels are a function of where you are in relation to the hub and whats in between the 2.
If you're home is right next to a hub, then you tend to have higher power levels. Sometimes you need to bring the power level down with an attenuator/splitter. Or if your home is to far away from the hub, you levels tend to be low and can cause issues.
Levels should be -7.5dbmv to 7.5dbmv for optimal levels. you're above that but its not causing errors. It potentially could cuase issues on the upload so you can always try adding a double or triple splitter into the line (with other junctions capped off) to see if bringing your levels down help or not.
