Spencerbullett
Feb 01, 2024Aspirant
CM1200 issues with cox connection
Recently I’ve been having issues with cox internet, and was told it was my equipment. I went and got a new modem and router, which surprise surprise didn’t fix the issues at hand. I’m getting packet l...
Feb 01, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
- SpencerbullettFeb 01, 2024AspirantThe wifi router is a Netgear nighthawk AX6-AX5400 I added the event log as well as the other spam of numbers
- FURRYe38Feb 01, 2024Guru - Experienced User
That a R8000?
- SpencerbullettFeb 01, 2024AspirantNegative. I updated the information a minute after the responds, it’s the nighthawk AX6-AX5400
- SpencerbullettFeb 01, 2024AspirantStartup Procedure
Procedure Status Comment
Acquire Downstream Channel 843000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enabled BPI+
IP Provisioning Mode Honor MDD honorMdd(4)
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 21 843000000 Hz 7.2 dBmV 41.8 dB 0 0
2 Locked QAM256 1 723000000 Hz 6.5 dBmV 41.8 dB 0 0
3 Locked QAM256 2 729000000 Hz 6.4 dBmV 41.8 dB 0 0
4 Locked QAM256 3 735000000 Hz 6.3 dBmV 41.8 dB 0 0
5 Locked QAM256 4 741000000 Hz 6.2 dBmV 41.8 dB 0 0
6 Locked QAM256 5 747000000 Hz 6.2 dBmV 41.8 dB 0 0
7 Locked QAM256 6 753000000 Hz 6.2 dBmV 41.7 dB 0 0
8 Locked QAM256 7 759000000 Hz 6.1 dBmV 41.8 dB 0 0
9 Locked QAM256 8 765000000 Hz 6.1 dBmV 41.8 dB 0 0
10 Locked QAM256 9 771000000 Hz 6.2 dBmV 41.8 dB 0 0
11 Locked QAM256 10 777000000 Hz 6.3 dBmV 41.9 dB 0 0
12 Locked QAM256 11 783000000 Hz 6.5 dBmV 41.9 dB 0 0
13 Locked QAM256 12 789000000 Hz 6.7 dBmV 42 dB 0 0
14 Locked QAM256 13 795000000 Hz 6.8 dBmV 42 dB 0 0
15 Locked QAM256 14 801000000 Hz 7.2 dBmV 42.2 dB 0 0
16 Locked QAM256 15 807000000 Hz 7.2 dBmV 42.1 dB 0 0
17 Locked QAM256 16 813000000 Hz 7.3 dBmV 42.1 dB 0 0
18 Locked QAM256 17 819000000 Hz 7.4 dBmV 42.1 dB 0 0
19 Locked QAM256 18 825000000 Hz 7.5 dBmV 42.1 dB 0 0
20 Locked QAM256 19 831000000 Hz 7.6 dBmV 42.2 dB 0 0
21 Locked QAM256 20 837000000 Hz 7.4 dBmV 42 dB 0 0
22 Locked QAM256 22 849000000 Hz 7.2 dBmV 41.8 dB 0 0
23 Locked QAM256 23 855000000 Hz 7.3 dBmV 41.8 dB 0 0
24 Locked QAM256 24 861000000 Hz 7 dBmV 41.8 dB 0 0
25 Locked QAM256 41 405000000 Hz 4.6 dBmV 41.4 dB 0 0
26 Locked QAM256 42 411000000 Hz 4.7 dBmV 41.4 dB 0 0
27 Locked QAM256 43 417000000 Hz 4.7 dBmV 41.4 dB 0 0
28 Locked QAM256 44 423000000 Hz 4.7 dBmV 41.4 dB 0 0
29 Locked QAM256 45 429000000 Hz 4.9 dBmV 41.4 dB 0 0
30 Locked QAM256 46 435000000 Hz 4.9 dBmV 41.4 dB 0 0
31 Locked QAM256 47 441000000 Hz 4.9 dBmV 41.4 dB 0 0
32 Locked QAM256 48 447000000 Hz 5 dBmV 41.4 dB 0 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 1 5120 Ksym/sec 17400000 Hz 35.3 dBmV
2 Locked ATDMA 2 5120 Ksym/sec 23900000 Hz 36 dBmV
3 Locked ATDMA 3 5120 Ksym/sec 30300000 Hz 36.5 dBmV
4 Locked ATDMA 4 5120 Ksym/sec 36700000 Hz 35.5 dBmV
5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
Downstream OFDM Channels
Channel Lock
Status Modulation /
Profile ID Channel
ID Frequency Power SNR /
MER Active Subcarrier
Number Range Unerrored
Codewords Correctable
Codewords Uncorrectable
Codewords
1 Locked 0 ,1 ,2 ,3 159 300000000 Hz 8.1 dBmV 43.8 dB 2216 ~ 5975 2758489474 293329757 0
2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power
1 Not Locked 0 0 0 Hz 0 dBmV
