triplea333
Apr 26, 2020Tutor
CM1200 issues with Xfinity ISP and Google Wifi Router
I have Xfinity as ISP and I'm trying to ditch their Xfi (modem/ router) and cut the monthly rental fee but I'm having the hardest time trying to set up my google wifi routers to it. It continues saying the modem and router must be restarted. I've gone online and researched forums (not really much written on this model). I tried everything with the original Xfi router and it worked so it must be something with my CM1200. PLEASE HELP!
did you get it activated?
Was your isp able to see it?
Once activated, log into it and take a screen snip of your modem connections page.
Make sure you only have 1 device connected to the cm1200. It does have 4 ports but the average use can only use 1 port.
I did get it activated.
My ISP sees it.
See screenshots attached of modem connections.
I only connected the google nest router to it; although I'm not sure why I would not be able to use all 4 ports of it - for that I would have just gone for the CM1100 which has only one ethernet port.
Your help is very much appreciated.
Review the user manual on getting a wifi router connected. Also review the user manual for your mfr wifi router as well.
triplea333 wrote:I have Xfinity as ISP and I'm trying to ditch their Xfi (modem/ router) and cut the monthly rental fee but I'm having the hardest time trying to set up my google wifi routers to it. It continues saying the modem and router must be restarted. I've gone online and researched forums (not really much written on this model). I tried everything with the original Xfi router and it worked so it must be something with my CM1200. PLEASE HELP!
I have done that multiple times, reset everything and tried again from scratch and nothing.
