Jc777
Apr 27, 2020Tutor
Cm1200 keeps dropping the internet
I have had this modem for a couple months and it keeps turning off rebooting kicking/dropping my internet connection I called my internet supplier numerous times even had a service tech come out to ma...
Apr 29, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Factory reset the modem and let it resync with the ISP service.
Contact a forum moderator for additional help and information about RMAs.
Jc777 wrote:
I have had this modem for a couple months and it keeps turning off rebooting kicking/dropping my internet connection I called my internet supplier numerous times even had a service tech come out to make sure all there stuff is okay. He witnessed it power down. I have called support numerous times about this issue and they still haven't fixed it I requested a replacement and they refused they said a supervisor/manager would call or email me and never did this thing is ridiculous horrible customer service can't even understand what they are saying and they have zero knowledge of there products I have been a dedicated netgear buyer. I'm going to try out there competitors cause this is beyond me I requested since you don't want to fix this issue ill send it back just give me a refund and they said its out of that time frame and chuckled. Negative 10 for customer service and support.
Jc777
Apr 29, 2020Tutor
Yes I did all of that the tech from my internet provider checked for a splitter and everything that is on there end and it was working properly. I did all those steps numerous times. And it still powers down on its on reboots. Or lose internet connection
I did the isp, reset it approximately 10 times
- FURRYe38Apr 29, 2020Guru - Experienced User
Make contact with one or both of the forum moderator to help you out. Ask about an RMA. Seems like the 1200 is just faulty and needs replaced.
