jlong01's avatar
jlong01
Follower
Aug 27, 2020
CM1200 LOG ERRORS - how to decode?
Hello,
Can anybody decode these warnings and notice event codes?
All seems to relate to the downstream OFDM Channel 159
Thanks
Joel
  • FURRYe38's avatar
    Have the ISP check the signal and line quality UP to the modem.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    What FW version is loaded on the 1200? Comcast is supposed to have a new v2 version out.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    what is the problem.
    it does not look that bad.
