dialup
Sep 21, 2020Tutor
CM1200 Loses Connection to ISP
After about seven months of use, my CM1200 has started losing connection with my ISP(Comcast). This started three days ago. At first, unplugging it would fix the issue, but within 24 hours I'd have ...
- Sep 22, 2020
Have the ISP check the signal and line quality UP to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
dialup
Sep 22, 2020Tutor
Thanks for the reply.
Here's the table. The event log is empty, which seems odd to me.
Cables have been checked and reseated. No splitters or amplifiers.
We had a good connection at 6am, but it went bad sometime in the morning. Right now, it keeps going in and out, lasting for maybe a few minutes at a time.
Sep 22, 2020Guru - Experienced User
- dialupSep 22, 2020Tutor
Comcast is sending a technician on the 24th. Whatever diagnostics they can run remotely didn't turn anything up.
Almost all of the modem reboots were power off, unplug, wait ~ a minute, plug in, power on. A couple of times it was left unplugged for several minutes.
