hubbles_law
Dec 14, 2022Aspirant
CM1200 losing speed right after reboot
Background - about 48 hours ago, I noticed my internet slow down and struggling. Since then whenever I run a speed test I wind up with ~30Mbps Down | ~20Mbps Up and should be around 1Gbps Down, I cal...
Dec 14, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- hubbles_lawDec 14, 2022Aspirant
Thanks for the reply, here are the details:
Enable Extended Upstream Transmit Power is Unchecked
Ethernet Port Aggregation is DISABLED
Startup Procedure Procedure Status Comment Acquire Downstream Channel 603000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels (Partial Service) Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 15 603000000 Hz 1.6 dBmV 39.4 dB 0 0 2 Locked QAM256 1 519000000 Hz 1.6 dBmV 39.7 dB 0 0 3 Locked QAM256 2 525000000 Hz 1.6 dBmV 39.6 dB 0 0 4 Locked QAM256 3 531000000 Hz 1.7 dBmV 39.6 dB 0 0 5 Locked QAM256 4 537000000 Hz 1.8 dBmV 39.7 dB 0 0 6 Locked QAM256 5 543000000 Hz 1.6 dBmV 39.7 dB 0 0 7 Locked QAM256 6 549000000 Hz 1.5 dBmV 39.7 dB 0 0 8 Locked QAM256 7 555000000 Hz 1.2 dBmV 39.6 dB 0 0 9 Locked QAM256 8 561000000 Hz 1.5 dBmV 38.9 dB 0 0 10 Locked QAM256 9 567000000 Hz 1.1 dBmV 39.5 dB 0 0 11 Locked QAM256 10 573000000 Hz 1.1 dBmV 39.1 dB 0 0 12 Locked QAM256 11 579000000 Hz 1.4 dBmV 39.5 dB 0 0 13 Locked QAM256 12 585000000 Hz 1.1 dBmV 39.4 dB 0 0 14 Locked QAM256 13 591000000 Hz 1.3 dBmV 39.4 dB 0 0 15 Locked QAM256 14 597000000 Hz 1.6 dBmV 39.5 dB 0 0 16 Locked QAM256 16 609000000 Hz 1.2 dBmV 39.3 dB 0 0 17 Locked QAM256 17 495000000 Hz 0.6 dBmV 39.6 dB 0 0 18 Locked QAM256 18 501000000 Hz 0.6 dBmV 39.5 dB 0 0 19 Locked QAM256 19 507000000 Hz 1 dBmV 39.5 dB 0 0 20 Locked QAM256 20 513000000 Hz 1.2 dBmV 39.6 dB 0 0 21 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 22 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 23 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 24 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 36800000 Hz 50.5 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 30350000 Hz 50.8 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 23900000 Hz 50.8 dBmV 4 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Time Priority Description Thu Dec 15 01:13:13 2022 Notice (6) CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:12:09 2022 Notice (6) CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:12:07 2022 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:56 2022 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:53 2022 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:49 2022 Notice (6) TLV-11 - unrecognized OID;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.7;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.6;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.5;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.4;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.2;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:48 2022 Error (4) Missing BP Configuration Setting TLV Type: 17.1;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Thu Dec 15 01:11:47 2022 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:ca:e5:c8:c8:ea;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:a0:db:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Dec 15, 2022Guru - Experienced User
You have lots of errors and criticals that the ISP needs to review and resolve.
Be sure to have them check the other suggestions as well.
- hubbles_lawDec 15, 2022Aspirant
I'll reach back to them with the details on the errors.
Are you able to expand or link me to more information about:
"Be sure the ISP provisions the modem correctly."
I've been reading that the bootfile which is controlled by my ISP could be an issue if they recently changed my plan but I'm not finding much research on what that entails.
