JSN007
Feb 09, 2024Aspirant
CM1200 losing speed
Did this users problem ever get solved?
Feb 10, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- JSN007Feb 10, 2024Aspirant
- FURRYe38Feb 10, 2024Guru - Experienced User
Can you please post the cable connections status page as well...
So…..I decided to invest in a new CM2000 since the 1200 was about 8 years old. Turns out the new CM2000 is doing the same thing so I logged a case with Netgear support. They looked at the logs and noticed that there were critical T3 and Sync errors (which seemed to coincide with the speed drops). In addition in looking at the connection page they saw upstream and downstream channels with power values outside of proper ranges. Therefore, I am going to have Cox back out to reexamine cabling, even though in two previous visits they say it’s fine. This is both frustrating and exhausting. For others who might be looking at this string, don’t assume it’s your equipment. More to come if this ever gets resolved with cox.
