HOLO
Apr 18, 2020Tutor
CM1200 Massive Bufferbloat
CM1200 suffering massive bufferbloat issues when used with Comcast, who "supports this modem". Current setup: CM1200 ---> XR500 ---> Desktop computer (hard wired) Scenario: I recently move...
- Apr 22, 2020
Just went out to best buy and purchased a Motorola MB8600. Issue is resolved. Will not be purchasing any netgear modems in the future and strongly advising my clients against it, the routers seem solid enough.
Apr 20, 2020Guru - Experienced User
Log into the the modem and take a screen snip of your modem's cable connection page and post them back on here.
Also get your logs for us to see. Take a screen snip as its easier to interpret than a copy/paste.
You said you get worse bufferbloat when you're just running the modem. How are you testing bufferbloat?
Do you have link aggregation disabled on the cm1200?
And nothing else plugged into the cm1200?
