HOLO
Apr 18, 2020Tutor
CM1200 Massive Bufferbloat
CM1200 suffering massive bufferbloat issues when used with Comcast, who "supports this modem". Current setup: CM1200 ---> XR500 ---> Desktop computer (hard wired) Scenario: I recently move...
- Apr 22, 2020
Just went out to best buy and purchased a Motorola MB8600. Issue is resolved. Will not be purchasing any netgear modems in the future and strongly advising my clients against it, the routers seem solid enough.
Apr 20, 2020Guru - Experienced User
Log into the the modem and take a screen snip of your modem's cable connection page and post them back on here.
Also get your logs for us to see. Take a screen snip as its easier to interpret than a copy/paste.
You said you get worse bufferbloat when you're just running the modem. How are you testing bufferbloat?
Do you have link aggregation disabled on the cm1200?
And nothing else plugged into the cm1200?
HOLO
Apr 22, 2020Tutor
Testing bufferbloat with dslreport, I've considered trying various software but it shouldn't matter - the issue is 100% the modem, considering comcast just checked the entire line and said it was perfect. The only thing I haven't been able to do is check with a different modem. Link aggregation is off, I've tried it on as well - no difference. There is nothing else plugged into the device other than my router - or in the case of testing just my pc with the modem, just my pc.
- plemansApr 22, 2020Guru - Experienced User
Then that'd be the next step.
I've got a cm1000 and cm1100 and both pass bufferbloat on xfinity.
Maybe you do have a bad one.
- HOLOApr 22, 2020Tutor
I can't say with complete certainty, but given what comcast has said about my line being perfect - It's not just a bad "one", it's a bad model. CM1200 is currently running firmware that just doesn't work, atleast with comcast. Do not buy this modem until it's fixed. I've had two brand new CM1200's that suffered this issue without any variation. After spending 3 hours with netgear support and 6 hours with comcast support, these are my findings. Netgear support just links me to guys in India who don't even know how to troubleshoot other than to tell me to plug it into my pc and restart / reset.
HOLO wrote:I can't say with complete certainty, but given what comcast has said about my line being perfect - It's not just a bad "one", it's a bad model. CM1200 is currently running firmware that just doesn't work, atleast with comcast. Do not buy this modem until it's fixed. I've had two brand new CM1200's that suffered this issue without any variation. After spending 3 hours with netgear support and 6 hours with comcast support, these are my findings. Netgear support just links me to guys in India who don't even know how to troubleshoot other than to tell me to plug it into my pc and restart / reset.
there's not much to troubleshoot with modems. If the lines good, the only thing you can change is link aggregation.
they either work or they don't.
Again, I've got the cm1100 and the cm1000 and both have been A rated for buffer bloat.
I've also used the Arris sb8200 with the same A rating for bufferbloat.
all 3 hit around the same exact speeds.
I wouldn't recommend link aggregation on any of them.
