enciberpangel
Apr 10, 2022Aspirant
CM1200 Modem - Drops In & Out & Slows Down (Suddenlink)
Hi all, This is my first time owning my own modem and router and I'm still attempting to learn and navigate my way through all the terminology and specs. I'm in need of some serious help though beca...
Apr 11, 2022Guru - Experienced User
Ok so your correct and un-correctables should be zeros.
Check all your cables and coax jack fittings to make sure they are screwed in well. ISP will need to look into this.
The power a bit too high as well:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
enciberpangel
Apr 11, 2022Aspirant
Would the fact that both me and my friend have to be wired in via ethernet to the modem/router for work be affecting anything? Right now, my ethernet is connected to the Modem and her ethernet is connected to the router.
Thank you!
- FURRYe38Apr 11, 2022Guru - Experienced User
What brand and model# router do you have connected to the CM modem?
The CM modem is a modem only. So for testing and getting the problems on the modem resolved, disconnect the external router and leave the wired PC connected while your testing and getting information from the modem.
Once you have the ISP resolve the issues outlined in my prior post, remove the wired PC from the modem and connect the external wifi router to the modem.
Power OFF the modem and wifi router for 30 seconds then power ON the modem first, then power ON the wifi router.
Connect your wired PC to the router.
