Mcuev2
Sep 02, 2020Aspirant
CM1200 Modem + R7800 X4S Connection Issues Nightly
Alright so for background I am running the CM1200 with a R7800 X4S router. I have Comcast (Xfinity) and pay for up to 600down. I am the only person in my house connecting to the internet, and when th...
Sep 02, 2020Guru - Experienced User
due you have the CM1200 setup with wan port aggregation enabled?
Mcuev2
I do not - it is currently disabled. I have not modified anything from factory settings.
- FURRYe38Sep 02, 2020Guru - Experienced User
You'll need to have the ISP check the lines. Have a tech come out and check as well if possible.
- Mcuev2Sep 02, 2020Aspirant
I figured this was the next step; they are sending an "engineer" this time who will check the lines they say. Hopefully he is able to find something.
