colexa
May 23, 2020Initiate
CM1200 modem activation with no ethernet port
Considering it's a wireless world now, why would Netgear force you to create a hard connection with your modem and computer on setup??? I have a macbook pro and they no longer have ethernet ports. ...
AdeptMaven
May 24, 2020Guide
All modems are ethernet only. To connect wirelessly you'd have to either A, buy a router or B, return the cm1200 and buy a modem/rodem combo. You can also buy a usb/usb-c to ethernet adapter. Hope that helps
