colexa
May 23, 2020Initiate
CM1200 modem activation with no ethernet port
Considering it's a wireless world now, why would Netgear force you to create a hard connection with your modem and computer on setup??? I have a macbook pro and they no longer have ethernet ports. ...
May 24, 2020Guru - Experienced User
so go modem----->router----wireless device?
you can do that. Isn't always as smooth but it does work and i've done it.
But its just a modem. If you'd wanted wireless integrated into it, you'd need to buy a modem/router combo device as the minutes you add wireless, you need routing functions.
colexa
May 24, 2020Initiate
That’s what I ended up doing. The instructions imply you have to go modem to computer before installing the router to then connect wirelessly which was my issue. Netgear just needs to update their documentation that ships with the product because skipping the computer step worked fine. Thx!
