Zram33
Dec 18, 2021Aspirant
CM1200 modem all lights green but no internet connection
All of the lights are green on the CM1200 cable modem but I still don’t have an internet connection. The router, and both tv’s that are directly connected to the modem all say they are not receiving a...
Dec 18, 2021Guru - Experienced User
The CM1200 modem is not a router. The 4 ports in back are for ISP WAN IP address assignments only. Most ISPs only assign 1 IP address at a time to a WAN Port on the modem.
You need a external wifi router to connect to the CM modem...Then you can have lots of devices connected to the router.
Zram33
I have my router, a nighthawk AC1900 wire connected to the modem through 1 of the 4 ports on the back of the modem, I have 2 TVs also wire connected to the back of the modem. The router then provides the WiFi signal throughout the house. It has been set up this way for the last 12 months and worked just fine. I wake up this morning and no WiFi and no tv.
- FURRYe38Dec 18, 2021Guru - Experienced User
You need to connect the TVs to your wifi router as well.
