Tonymontanaalb
Jul 18, 2021Tutor
CM1200 Modem and noise issues
Hello everyone. So, I’ve been having an issue with my connection for the longest time and its time I get some help from some very smart people out there. I have Suddenlink 1Gb down and 35 up plan. Lo...
- Jul 19, 2021
No.
You have errors in the line as evidenced by the logs.
your power levels are a touch high but technically still within spec, just not optimal.
and you have 1 channel with issues on the upstream
Jul 19, 2021Guru - Experienced User
You signal is a little hot (to high) but you don't have detected errors in the line.
but your logs indicate quite a few errors.
I'd check your line for kinks, damage, old/bad/loose/cheap connectors and replace them.
Remove splitters/amplifiers from the line as well.
If you've rulled all that out, then you'd want suddenlink to check the line
