BenRoberts
Oct 26, 2022Aspirant
Cm1200 Modem dropping connection. Unstable intermittent internet
As the title states that is the problem. Xfinity is trying to tell me its my modem is bad. I suspect it is old cable lines that are making “ noise” in the line causing the poor connection. I was chatt...
Oct 26, 2022Guru - Experienced User
You have lots of criticals and some errors that the ISP needs to review and help resolve.
https://highspeed.tips/docsis-events/
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Can try a different modem to see if the problem continues or not.
- plemansOct 27, 2022Guru - Experienced User
Your logs indicate a line issue.
But your cable connections page doesn't look to bad. A little out of spec on the power but not a ton. (supposed to be within 3.5dbmv of each other on the downstream channels).
Next time you run into the issue, then pull the cable connections page as it takes a snip of it when you open it up. When the upstream flasheds, its usually indicating that only 1 of the upstream channels is locked. Which will cause issues. But its also important to determine whats going on with the downstream at the same time the upstream is having issues.
