bcooper27
Jan 22, 2021Star
CM1200 Modem Dropping Connection
Just recently installed the Netgear CM1200 modem to support the 1G Internet service I upgraded to from my ISP "RCN" here in Pennsylvania. I also have an RAX70 Netgear Nighthawk (also new) attached and both are brand new. I've had 2-3 instances of dropped connections on my CM1200 over the last week since I installed it. Both times the DOWNSTREAM light on the modem was just flashing green and we had no service in the house. Both times I turned off the modem by using the power button, kept it off for a minute, turned it back on. And both times within a minute or so the modem would eventually go all green solid lights and we'd hear the pings on our equipment that the Internet service was back on.
I did read other posts that some people have had the same issue. I read some said to check wiring, splitters, etc. Note that this is an upgrade from our previous setup which was a CM600 Netgear Modem with a Netgear Nighthawk X8 R8500 which both worked flawlessly when we had the 250M Internet service from RCN. So the wiring is not an issue.
Below are the event logs from the issue last night. If anyone has any suggestions I would appreciate it. Obviously I want to make this work but I can't afford to continue manually resetting the modem to get things up and working every time. It shouldn't be that way. Thanks in advance. - Brian
| Time | Priority | Description |
| Fri Jan 22 11:28:26 2021 | Warning (5) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:24 2021 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:19 2021 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:19 2021 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:19 2021 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:19 2021 | Error (4) | Missing BP Configuration Setting TLV Type: 17.7;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:19 2021 | Error (4) | Missing BP Configuration Setting TLV Type: 17.6;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:19 2021 | Error (4) | Missing BP Configuration Setting TLV Type: 17.5;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:19 2021 | Error (4) | Missing BP Configuration Setting TLV Type: 17.4;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:19 2021 | Error (4) | Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:19 2021 | Error (4) | Missing BP Configuration Setting TLV Type: 17.2;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:19 2021 | Error (4) | Missing BP Configuration Setting TLV Type: 17.1;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Fri Jan 22 11:28:18 2021 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=08:36:c9:a4:46:d8;CMTS-MAC=2c:0b:e9:14:b0:e9;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
do you also have a screen snip of the cable connections page? that helps in conjunction with the logs.
Well I've tried twice to add the Cable Connection snippet and twice my post disappears. Any other way to add this?
Click on "choose file" when adding. You'll only be able to add one at a time.
