jf6791
Dec 18, 2023Guide
CM1200 Modem Log has same single entry all the time
We've been troubleshooting network dropout issues and trying to glean some info from the modem log. The problem is every time it is accessed the same entry exists "Started Unicast Maintenance Rangin...
Dec 19, 2023Guru - Experienced User
Has a factory reset been performed on the modem with out the ISP coax cable connected to the modem?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
- jf6791Dec 26, 2023Guide
So after a factory reset the logs are back to normal - as far as retaining older entries. Screenshots of levels and logs are below. The router is an RAXE500.
Procedure Status Comment Acquire Downstream Channel 603000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 29 603000000 Hz 4 dBmV 43.2 dB 0 0 2 Locked QAM256 13 507000000 Hz 3 dBmV 43.1 dB 0 0 3 Locked QAM256 14 513000000 Hz 3 dBmV 43.1 dB 0 0 4 Locked QAM256 15 519000000 Hz 2.7 dBmV 43 dB 0 0 5 Locked QAM256 16 525000000 Hz 3.1 dBmV 43.1 dB 0 0 6 Locked QAM256 17 531000000 Hz 3.2 dBmV 43.1 dB 0 0 7 Locked QAM256 18 537000000 Hz 3 dBmV 43 dB 0 0 8 Locked QAM256 19 543000000 Hz 2.8 dBmV 43 dB 0 0 9 Locked QAM256 20 549000000 Hz 2.7 dBmV 42.9 dB 0 0 10 Locked QAM256 21 555000000 Hz 2.8 dBmV 42.9 dB 0 0 11 Locked QAM256 22 561000000 Hz 3 dBmV 42.9 dB 0 0 12 Locked QAM256 23 567000000 Hz 3.4 dBmV 43.1 dB 0 0 13 Locked QAM256 24 573000000 Hz 3.4 dBmV 43.1 dB 0 0 14 Locked QAM256 25 579000000 Hz 3.5 dBmV 43.1 dB 0 0 15 Locked QAM256 26 585000000 Hz 3.6 dBmV 43.1 dB 0 0 16 Locked QAM256 27 591000000 Hz 3.7 dBmV 43.2 dB 0 0 17 Locked QAM256 28 597000000 Hz 3.7 dBmV 43.2 dB 0 0 18 Locked QAM256 30 609000000 Hz 3.9 dBmV 42.9 dB 0 0 19 Locked QAM256 31 615000000 Hz 3.7 dBmV 42.8 dB 0 0 20 Locked QAM256 32 621000000 Hz 4.2 dBmV 43.1 dB 0 0 21 Locked QAM256 33 627000000 Hz 4.2 dBmV 43.1 dB 0 0 22 Locked QAM256 34 633000000 Hz 3.9 dBmV 43 dB 0 0 23 Locked QAM256 35 639000000 Hz 3.8 dBmV 42.9 dB 0 0 24 Locked QAM256 36 645000000 Hz 3.8 dBmV 42.9 dB 0 0 25 Locked QAM256 37 651000000 Hz 3.5 dBmV 42.7 dB 0 0 26 Locked QAM256 38 657000000 Hz 3.1 dBmV 42.6 dB 0 0 27 Locked QAM256 39 663000000 Hz 2 dBmV 41.9 dB 0 0 28 Locked QAM256 40 669000000 Hz 1.4 dBmV 41.6 dB 0 0 29 Locked QAM256 41 675000000 Hz 2.5 dBmV 41.7 dB 0 0 30 Locked QAM256 42 681000000 Hz 3.1 dBmV 42.9 dB 0 0 31 Locked QAM256 43 687000000 Hz 3.5 dBmV 43 dB 0 0 32 Locked QAM256 44 693000000 Hz 3.4 dBmV 43 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 16400000 Hz 50.3 dBmV 2 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 50.3 dBmV 3 Locked ATDMA 4 5120 Ksym/sec 29200000 Hz 49.8 dBmV 4 Locked ATDMA 5 5120 Ksym/sec 35600000 Hz 49.8 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 ,3 159 702000000 Hz 4.9 dBmV 43.2 dB 1126 ~ 2969 336941441 61659 0 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Extended Upstream Transmit Power Enable Extended Upstream Transmit Power Current System Time:Tue Dec 26 21:02:09 2023 System Up Time:02:49:32 Clear Log Refresh Time Priority Description Tue Dec 26 20:36:59 2023 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; Tue Dec 26 18:25:34 2023 Notice (6) CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: �; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; Tue Dec 26 18:25:30 2023 Warning (5) DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; Tue Dec 26 18:25:30 2023 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=28:80:88:b3:96:68;CMTS-MAC=04:2a:e2:c7:7c:ed;CM-QOS=1.1;CM-VER=3.1; Tue Dec 26 18:19:45 2023 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=;CMTS-MAC;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Dec 26, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STA
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/- jf6791Dec 27, 2023Guide
Can I advise the ISP that any of the levels are out of spec?
