jf6791
Dec 18, 2023Guide
CM1200 Modem Log has same single entry all the time
We've been troubleshooting network dropout issues and trying to glean some info from the modem log. The problem is every time it is accessed the same entry exists "Started Unicast Maintenance Rangin...
jf6791
Dec 26, 2023Guide
So after a factory reset the logs are back to normal - as far as retaining older entries. Screenshots of levels and logs are below. The router is an RAXE500.
| Clear Log Refresh | |||||||||||||||||||||||
Dec 26, 2023Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STA
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
- jf6791Dec 27, 2023Guide
Can I advise the ISP that any of the levels are out of spec?
- FURRYe38Dec 27, 2023Guru - Experienced User
Power levels are with in spec:
